justme
Dec 09, 2015Explorer
joebedford wrote:If you have 7K axles with 4 brake drums 1 ohm would be reasonable. Each magnet would be about 4ohms with 4 in parallel to end up with 1 ohm. Of course there is a little resistance in the wire going to the magnets. My 4 magnets in parallel measure 1.1 ohms at the plug. With 6 magnets in parallel you should measure approx. .7 ohms.
My 5ers brakes aren't working. Trying to figure out if it's the truck (2011 Silverado HD) or the trailer (Voltage 3950).
While doing continuity checking of the cables and connectors, I disconnected the two leads that go from the cable junction box (on 5er) to the brakes. I got 3.3 ohms. Is that normal for a tri-axle?
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
