- ReneeGExplorerDefinitely has to be a misprint.
We have a 2011 F350 DRW crew cab, 4x4:
Conventional towing - 17,500
Fifth Wheel towing - 21,300 - BurbManExplorer IIIProbably 19,840...a 5er puts the hitch weight in the bed over the rear axle, where a conventional trailer attaches to the frame at the back of the truck. The distance between the axle and the back of the truck acts as a lever arm on a conventional trailer so puts added stress on the suspension, where the 5er's pin weight is loading straight down.
- valhalla360NavigatorThere is likely a typo on the rating.
But 5th wheels do generally get a different tow rating but it's usually higher and not typically a 50% difference.
For example: We have a 2008 F250 Crew Cab Short Bed V10 4.10 rear end.
- Conventional Towing 12,500
- 5th Wheel Towing 14,500 - MFLNomad IIIt would help to know what model and year Ram. I'm thinking 3500, likely DRW?
Jerry - wanderingaimlesExplorer"5TH-WHEEL TOWING CAPACITY (LBS.) 9,840"
Maybe a mistake for Kg? - KD4UPLExplorer IIThat can't be right. Are you sure the 5th wheel capacity isn't 19,840? Usually the FW cap is more than the "regular" hitch cap.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
