srosa
Jan 31, 2014Explorer
Old-Biscuit wrote:srosa wrote:
Leaky back flow preventers is a common problem. Universal replacement kits are available online for $20 to $30. Leaving a hose connected to the black tank flush can cause these to valves to stop working and leak.
Please explain what you mean by that statement.
I'm not understanding the situation or concern.
Thanks
The backflow preventer kits are a common repair part so they do fail from time to time. I ruined one by leaving a garden hose hooked to the flush inlet on a very hot day. The end of the hose was plugged by a closed spigot and the pressure ruined the check valve. Water then backed up into the valve when flushing the tank and it leaked. The tank flush quit working too until I replaced its backflow preventer. I went with a brass one instead of plastic. Works great again with no leaks.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
