- LantleyNomad
taken wrote:
There's an answer that you already speculated Lantely and discussion of it causes threads to be locked...
Taken I took an educated guess,but I was hoping to do better than my speculation. I was hoping that someone with more official knowledge could confirm or refute my speculation.
Have the ST vs. LT criteria become some sort of secret that can't be discussed?
Has it become a taboo discussion for fear of locking the thread.
Funny there is already one pre-locked thread out there already.
More importantly what if my speculation is wrong? I hate to spread misinformation. There plenty of fake news already without adding the ST vs.LT ratings to the fray.
It's a simple question, why is the ST load rating higher than the LT load rating assuming we are referring to the exact same tire and it is only a ST.vs. LT ratings change due to taxes and tariffs?
Anyone else care to speculate. - takenExplorer III think your speculation is completely correct but can't offer any collaboration other than reading it a million times added to the fact that it just makes sense. It really doesn't matter to me but I'm sure the proof is out there if someone wanted to look hard enough.
- LantleyNomad
You're right maybe I'm just the lazy one. My cursory search didn't turn up anything. - JIMNLINExplorer IIIKinda what tireman9 says in his rv tire safety blog where he talks with a TRA engineer about the need for ST tires to have their capacity reduced up to 25%.
Tireman9 says;
**Finally chased down the answer. Getting to the bottom was a challenge because I ran into "customer service" people who could read from a script but had no idea why they were giving me the answer they were.
Even got to an engineer at Tire & Rim Association and based on his answers it was obvious TRA had not thought about ST type tires or the unique nature of most RV trailer applications for many years so I believe he acted a little surprised when I identified the engineering analysis that indicated that the current loads too high for many trailers and that the load capacity should be decreased by 15% to 25% or more if the failure rate was to be decreased to a more tolerable rate rather than the 5 or 10% or higher some are reporting. This is not his or TRA fault as I understand it is the responsibility of tire company representatives to TRA to present and review technical matters.**
You might drop over on Tireman9 and ask him your questions.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
