MTPockets1
Dec 30, 2014Explorer
Based on your info - GVWR 8800 and actual weight of 6640, you have a payload capacity of 2260 lbs. now, if passengers, hitch, cargo and a full tank of fuel were in truck when you weighed, 2260 lbs is the maximum weight you can add on the hitch pin. If those were not in the truck, you will have payload capacity limit less by the weight of items mentioned. Total weight of trailer is limited by the pin weight capacity of your truck.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 12, 2026
