ACZL
May 30, 2015Explorer
What to do? 5er not level w/ truck
I think a similar post was done about this very thing, sorry if it's a repeat.
With units in sig, here's my problem. Hooked up and truck hitch in lowest setting, I have 7 1/2" gap between box rail and nose cone. At tailgate, the gap is 6". Under normal circumstances, no problem per se. But I have a tonneau cover on truck and it's rails stick up 1-1 1/2" above top of box rails. If both rigs get to "wobbling" good chance back end of truck could pop a hole in underside of 5er.
Both front and rear spring shackle brackets have 3 holes in them (springs currently mounted in top hole closest to frame). Center shackle/rocker box bracket has 2 holes and currently in top hole (again closest to frame if you will). Equa-Flex suspension installed. My thinking is to raise the rear of trailer by lowering it 1 hole on all 6 shackles.
Spoke w/ dealer who wasn't sure and advised to speak w/ Cedar Creek to see if it would fall within their tolerances if done. CC said I should try to accomplish the gap issue via hitches only and to talk w/ axle mfr ( in my case, Lippert). So call Lippert and they cannot tell me what to do vis liability concerns if I do it and something goes wrong. Getting more stumped at this point.
Call Ford dealer up to pick their brains about this and if other have had same issues. They knew of one person who did but couldn't recall what the solution was other than possibly switching out the spring spacers to smaller ones. I could see where this would "lower" rear end of truck (I think) and thus eliminate or increase the tailgate gap and 5er should ride level. They are to look into it (thru Ford???) and get back to me.
Truck has 18" tires. Would there be any problems by lowering the susp 1 hole? Is that what the holes in brackets are for OR just generic brackets? What have others done?
Next trip not for a few weeks.
Thank you in advance
