scrollmasterExplorerSep 14, 2013What to seal Water Heater with around RV body2001 Jayco Quest 5th Wheel, 6 Gal Atwood Water Heater... Had to remove the water heater to replace cold water shut off valve. It appears that it was sealed with plumbers putty between water heater an...Show More
Me_AgainExplorer IIISep 14, 2013That is not plumbers putty. It is a RV bedding compound. Should be available at most RV stores. Chris
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Tankless water heater
