janegowest wrote:
Looking at a 5er with these specs:
Length: 32'4"
Height: 12'8"
Dry axle weight: 9,215
Hitch weight: 2,090
Dry weight: 11,305
Average load capacity: 3,694
What truck would we need to safely navigate mountains, like Yosemite? It seems like if we want 4 season, it always gets heavier!
Thanks for your help!
We just purchased a 5er with similar specs.
The hitch weight is your area of primary concern IMO. One thing's for sure, you can count on the manufacturer's advertised "empty" hitch weight to be a low-ball number based on a unit with zero options. This low-ball number aside, all your personal gear will certainly increase this number substantially regardless.
The 2300 lb. advertised "empty" hitch weight of our unit increased to 2800-2900 lbs. lightly loaded for the realworld. We tow with a '16 Ram 3500 6.7 SRW with a payload of 3960 lbs. After adding the weight of the hitch assembly, a passenger, and some light gear in the back seat, we only had/have 700 lbs. of payload remaining.
If you're one who likes to be within all the maximum ratings (and not just the RAWR), a 3/4 ton diesel will not be enough truck in terms of payload numbers. You may be able to squeeze by with a 3/4 ton gasser which typically has a bit more payload than their diesel brethren, but it would be close.
Good luck!
