larry_barnhart
Sep 05, 2014Explorer
Ammonia did not work for me on the red max pro. the stripper from Zep will do the job but not as it shows because it id for a flat surface and it is hard to tip the fifth over. Joke of course. I learned to use the stripper straight and wet the surface and apply using a Dobie product with some grit. Do small area's and you will learn as I learned from doing it. the product will get yellow and this is telling you it is coming off. It will take several attempts. I used a plastic putty knife at times. It is a learning project. when I had what I thought was good I blasted that area with water. Probably will take several attempts for getting it off. Also working on a cool day and not in the sun was a big help.
chevman
chevman
About Fifth Wheel Group
