B_O__Plenty
Sep 05, 2014Explorer II
larry barnhart wrote:Knowing all this, now I think I'm sorry I tried it.
Ammonia did not work for me on the red max pro. the stripper from Zep will do the job but not as it shows because it id for a flat surface and it is hard to tip the fifth over. Joke of course. I learned to use the stripper straight and wet the surface and apply using a Dobie product with some grit. Do small area's and you will learn as I learned from doing it. the product will get yellow and this is telling you it is coming off. It will take several attempts. I used a plastic putty knife at times. It is a learning project. when I had what I thought was good I blasted that area with water. Probably will take several attempts for getting it off. Also working on a cool day and not in the sun was a big help.
chevman
B.O.
About Fifth Wheel Group
