One tool that some folks may not consider is a tire valve stem removal tool. It's a good idea to check your valve stems for tightness occasionally because if one loosens you'll have a slow leak and gradual reduction in air pressure. I've had this happen before, thinking it was an object stuck in the tire but it turned out to be a loose valve stem.
I carry the same tool when on my bicycle so when I get a flat I can completely remove the valve and inject "green slime" into the tire to seal the flat. It's a little tool but so handy when needed.
