anaro
Jul 21, 2014Explorer
To give you an idea on the pin weight. I just weighed my 5er today. It had 11104 lbs dry (yellow sticker) weight and a gvwr of 13888 (per plate on side of trailer). Dry brochure pin weight was 1880. Weights loaded at the scales were a pin weight of 2620 lbs and a trailer weight of 12380 lbs. This is within my 3500 SRW specs, not your 2500 specs. The 5er you are talking about is actually dually territory.
Once you hit the scales, I think you will find your current fiver to be at the top of your range.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
