JIMNLIN
Jul 23, 2014Explorer III
op asks wrote:
What's the comfortable weight limit ??
I and my trucks are comfortable towing the trucks max GN/5th wheel tow rating and carrying loads up the the truck mfg RAWR as its carrying the load. I run my trucks usually over 200k miles with no break downs or causing a accident.
Some folks are only comfortable carrying loads determined by the trucks GVWR or number from GCWR or the truck tire placard number or a 80 percent figure or any of several other numbers used.
Everyone has their own comfort level. I have mine but I don't beat others over the head 'cause they don't do it like I do.
The OP would be better off going with a new gen one ton SRW or DRW. His choice there.
A 15.5 trailer simply has more pin weight than a 2500 RAWR is capable of carrying without mods to the trucks rear suspension (rear spring pack/wheels and tires). The rest of the truck is same as a 3500 SRW.
I use dry weights and GVWR and CCC when looking at any trailer including RVs. Reason being some trailers have large CCC numbers that I will never use. Trailers in the pre '00s era had as little as 650 lbs CCC as mine does.
Dry weights and CCC are very important for my use.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
