Justaguy
Oct 26, 2014Explorer
valhalla360 wrote:
Mostly, it means the marketers wanted to sell to folks with 1/2 ton trucks.
They generally are a little lighter but that's mostly because they are smaller with fewer slide outs.
The fact they have a hitch on the trailer doesn't mean a lot. 5th wheels are typically limited by the pin weight (not the pulling power). A small utility trailer on the back of the 5th wheel has very little effect on the pin weight (technically it probably pulls 50-100lbs off the pin weight since it pulls down on the back of the 5th wheel). Most 1/2 ton trucks can pull a lot more than they can carry.
X2 also, I have taken a factory tour and know for certain that the manufacturer uses smaller plumbing fixtures, less thick flooring and side walls. Much less insulation, less this and less that. I think they would be ok for a weekend type of camping or TT type of use. But long term or hoping they last a long time -- eh? Not so much.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
