ACZL's avatar
ACZL
Wheel bearing advice
Is there a right/wrong way on maintenance as far as replacing bearings/seals.......age (1x/yr or every 3 years etc) OR miles??? Both myself and a co-worker would like to know what you folks all think or do. I give mine 3-4 shots of grease every year but don't know about co-workers. Told him I'd ask as he's just as curious as me. Either I've been lucky or fortunate, but no probs is 4 years and approx 5-7k miles.
  • Do ours yearly, we travel around 10-15,000 miles. Tear them down, repack, change seal and adjust brakes.
  • I HAD those zerks 2 RV's ago and never used them...
    I will tear down the components at the beginning of each year to visually inspect. If the outter bearings or shaft look questionable, I will tear down into the inners and re do the seals as well.. For normal wear, I will repack each assembly probably every 2 years.
    disclaimer - - I am not a full timer, we are just weekend warriors , last year we only took 4 trips for a total RV rolling miles of about 3500 miles total.the truck did 5000 miles total last year
  • I check at the beginning of each long trip by removing the center cap. I also check the tire and hub temperature as I make stops along the way. If you use the back of your hand near the center cap as you walk around the unit you will notice any hub that is hotter than the others. Water submersion is the main reason to repack in my experience. I have gone through flooded areas and needed to repack right away and if I keep the axles out of the water I have waited as long as 20,000 miles and 5 years on the RV. On the boat I repack at the beginning of each season and check as mentioned above each time it is in the water.
