REWahoo
Jun 26, 2013Explorer
You can't take the Fisherman out of this Camper wrote:
Check all wheels.. including the tow vehicle and trailer tires/bearings. If you find one higher than the corresponding wheel/bearing or tire that's the one that requires a closer look i.e. tire pressure or bearing. Keep in mind that hard braking will also show up on the wheel close to the bearing(s). Any serious issue will show up with a considerably higher reading.
+1
Far too many variables to say what a good temp should be, the key is to watch for one considerably higher than the others.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
