ksbowmanExplorer IIJun 26, 2013wheel bearing and tire temperaturesWhen you use a digital infrared temperature sensor what are the acceptable temperatures for tires and wheel bearing in the summer? Basically when it is in the 90's outside.
VeebyesExplorer IIJun 27, 2013A simple walk around with a tire touch should tell if one is significantly warmer than the rest.
