ksbowmanExplorer IIJun 26, 2013wheel bearing and tire temperaturesWhen you use a digital infrared temperature sensor what are the acceptable temperatures for tires and wheel bearing in the summer? Basically when it is in the 90's outside.
dogwood36322ExplorerJun 27, 2013According to TST a tire failure begins from temp around 197 degrees F. It was stated in my tire pressure/temp monitor setup.
