rkassl's avatar
rkassl
Wheel Bearing Maintenance
When do most folks repack their wheel bearings, is it my time, like once a year or more like mileage?
Thanks!
  • RAS43's avatar
    RAS43
    Explorer III
    Likes to tow wrote:
    Every other year for me also. I replace the seals about every 4 years. Never do I use the grease fitting!! This is great for boat trailers that get submerged in water but it will hose down your brake shoes if the seal is not 100%.
    Why would you go thru the trouble of repacking the bearings and not replace the seals? The seal has to be removed to remove the inner seal anyway and they don't cost much. Just curious.
  • Every other year for me also. I replace the seals about every 4 years. Never do I use the grease fitting!! This is great for boat trailers that get submerged in water but it will hose down your brake shoes if the seal is not 100%.
  • Owner's manual says annually but I repack every other year. Never a problem but I do watch temperatures when towing.
  • Just had mine checked earlier this year(first time).
    Have about 30,000 miles, maybe more.
    Had trailer for five years.
    They all looked good.
    Pat
