Gray_FoxExplorerJul 26, 2016Wheel BearingThe axels on my 5th/w have grease fittings, how many miles do you go before you grease them again approx.
BB_TXNomadJul 26, 2016Assuming you have the Dexter EZ Lube axles, you don't just add a little grease every once in a while. You follow Dexter instructions and purge the old grease out while inserting new grease. EZ Lube videoThe grease actually goes to the rear bearing first before traveling out thru the outer bearing.
