justme wrote:
Forget the easy lube. It was intended for boat trailer and the RV mfg's use it as a good sounding marketing ploy. Grease and inspect your bearing/races the old fashion way every 8-12K miles or once a year and you will have less problems. If you are not comfortable doing it your self, have a reputable professional do it for you.
You mean take it to a dealer like the poster before you? Seems like there are quite a few people who post they had problems after a shop has done their brake/wheel bearing job.
Doing it every year is silly. I finally did check mine after 6 years and they are fine. Every year just means there's more chance of messing something up. It's probably not a bad idea to have them checked when new to make sure they're assembled correctly and properly greased. After that ever few years is fine, unless you're putting on some big miles every year: 15,000-20,000 miles. "If it ain't broke, don't fix it."
