jfkmk
May 24, 2017Explorer II
valhalla360 wrote:jfkmk wrote:valhalla360 wrote:fj12ryder wrote:
Every time you have the ones on your cars and trucks repacked. :)
Always wondered about that. I've had a number of vehicles hit 200k miles and never once repacked the bearings.
Most vehicles these days use sealed hub assemblies, which are run to failure, as you CAN'T repack the bearings. The axle manufacturer for my TT (Dexter) recommends 12 months or 12,000 miles, whichever comes first.
Everybody has their own preference and reasoning for how they maintain their trailer. I do all my own maintenance, including the bearing maintenance. The way I look at it, for the time and money I spend doing the bearing maintenance and brake check each year, it is extremely cheap insurance for a problem-free camping season.
As others have stated, the bearings come from the factory with the minimum amount of grease in them, so no matter how long you go between packing them, start out by doing so right away.
You'll get all kinds of advice here, some very good, some very questionable. In one thread, someone argued you never have to repack them, simply pop the grease cap, put a dab of grease in the cap itself (no, these were not ez-lube!) and you'll be good to go. Whatever you decide, remember not everyone is offering sound advice.
I wasn't suggesting not to do the scheduled maintenance.
I was asking why they don't use the same sealed bearings.
- Are they drastically more expensive?
- Can't handle the weight?
- Is it that RV's sit for weeks/months at a time (not buying this as I've seen lots of cars that sit for long periods without failing)?
I suspect long haul semi's don't go in every 2-4 weeks to have the bearings repacked (they can easily do 12k miles in a few weeks).
So what's different that RV bearings are so much worse?
I'm not sure why trailers don't typically use sealed bearings. Some do, but most don't. Perhaps it's because they may be used for boat trailer applications, and I don't think they do well in a submerged application.
I do wish I could service the bearings in my vehicles. I think the last serviceable bearings I had were on my 71 Challenger. I serviced the bearings every 30k or so, and never had a failure in more than 200k mikes, and that was 1971 technology.
Most of the vehicles I've had with the sealed bearings have failed at one point. Very expensive to have them replaced, and not too cheap even when I've done the work myself.
Truthfully, my annual repacking and maintenance is probably overkill. However for the ridiculously small amount of money and time I spend doing this, for me it is worth the assurance of not having an issue for the rest of the season.
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
