gmg
Nov 08, 2019Explorer
Wheel Bearings
We recently experienced a broken right side spring shackle. We actually drove about 500 miles on it before we discovered the problem. The trailer was sagging on the right side. The spring shackles wer...
Cummins12V98 wrote:Looks like you answered your own question.fj12ryder wrote:
Pretty much a temporary fix, after all grease is just basically oil in suspension.
OK how does one keep the oil in the cap once it gets turned so the oil doesn't fall out before re connecting cap???
If ya gots this system like I do ya pull plug n fill to bottom of hole and re install plug. Op most likely does not have this.
