gmgExplorerNov 08, 2019Wheel BearingsWe recently experienced a broken right side spring shackle. We actually drove about 500 miles on it before we discovered the problem. The trailer was sagging on the right side. The spring shackles wer...Show More
Cummins12V98Explorer IIINov 14, 2019The top "D" surface seats into hub like normal. The lower "D" grips the spindle, so there is no spindle wear.You could use this on a grease system also. The National Seals are US Made.
Related ContentWheel bearing repackingWheel BearingsWheel Bearing RepackWheel BearingsWheel bearing advice
