Jim2007's avatar
Jim2007
Wheel chock
Hi all; Can the Xwheel stabilizer product or the wheel stop product be used in place of conventional wheel chocks when unhooking or hooking up a fifth wheel trailer? Comments please. Jim2007
  • Some of those plastic ones are so flimsy they wouldn't stand up to any kind of very heavy weight.
  • What is wrong with the plastic ones that weigh a pittance of the rubber ones?
  • I forgot to remove one and it popped right out as soon as I moved the trailer. I use them to help stabilize it but don't trust them for parking.
    B.O.
  • I have X-Chocks, but I have the rubber wheel chocks on the ground when hitching/unhitching. X-Chocks are best described as "stabilizers".
  • I have a set of X chocks. I've looked at this myself and I don't think it would be wise. If you raise or lower the front of the trailer, the wheels actually move a little bit closer or farther apart. Same goes for setting the stab jacks and lifting one side of the trailer slightly.
    So you could set the X-chocks in one position and they could get very loose just by making an adjustment.
  • X-chocks stop back/forth rocking motion BUT are NOT 'recommended' in lieu of wheel chocks.
    The two together work best.
    Wheel chocks to stop the rig from rolling away and the X-chocks to help with that 'boat on water' feeling
    I have used just X-chocks (both sides) on my 5vr but only on fairly level sites. ANY slope for/aft I wheel chock first then x-chock and recheck that evening
    Wheel Stop....?
    Is that a different product or different description of X-Chocks?
  • I don't see why you couldn't. I do know as the tires cool down the chocks either kind will be loose. The standards are easier and faster for setup
