JIMNLIN
Dec 10, 2021Explorer III
Trailer axles require zero offset wheels....as in trailer wheels. Trailer Axle bearings are set up for the load to be between the inner and outer bearings.
Use the wrong offset and axle bearing won't last long.
From TX to TN may work for you. 17" tires from the truck may be to wide (tread and section width) so measure close.
About Fifth Wheel Group
