2-MTnesters
Dec 01, 2013Explorer
My opinion you have worn bearings. I would highly advise that you pull each wheel and inspect both inner and outer bearings and replace as necessary. I would also highly advise NOT using the EZ-lube system as its very easy to over grease and blow out the seal. If you do choose to continue using the EZ-lube system, you should rotate the wheel in the forward direction while pumping in the grease. This will help to evenly disperse the grease in the bearings.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
