MFL
Dec 01, 2013Nomad II
fj12ryder wrote:
They apparently put very little grease in these EZ-Lube hubs and it isn't unusual to have to use a lot of grease the first time you lube them up, which needless to say should have been a lot sooner than 12,000 miles. :)
And yes, you should raise the tire off the ground and spin it while lubing the bearing. Don't use a power grease gun and don't get in a big hurry. However yours doesn't sound too good.
This is correct, as the factory usually just greases the bearings enough to get by. My EZs needed a lot of slow easy pumps, before the hubs filled.
I can see the back side of the seals, using a piston light looking from the rear. There is several holes above, and to the side of brake adj hole. My seals have no leakage.
I also think the castle nuts may be loose, but best to have a look at the bearings/races after 12,000 miles.
Jerry
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
