JIMNLIN
Dec 02, 2013Explorer III
ScottG wrote:Allworth wrote:
Obviously Scott is smarter than all the Engineers at Dexter put together!
"If" they wrote that (I have the procedure for both dexter and Alko and don't see anything that says bearings should be lose..) then not only am I right but every experienced mechanic, trade school and knowledgeable DIYer is smarter.
Howard, you've got the idea. Even "snug" is not lose ie has play.
Loose is your term.
Dexter nor I nor anyone says they need to be loose and anyone that has any experience of using and replacing wheel bearings on heavy vehicles knows a pre loaded or snug bearing won't last long especially when carrying those heavy loads.
The OP will be wise to follow Dexters recommendations. Every new truck or trailer I put in service I pulled the hubs and check for proper grease and reset the bearings. When your on the road making a living its small things that can make for thousands of miles of event free service.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
