fj12ryder
Dec 02, 2013Explorer III
Tvov wrote:That basically is what preload means. Some instances will have a lot of preload, and you set the preload by measuring the amount of torque it takes to turn the shaft.
People keep saying "preload"... I take that means snugging the bearings so there is no play at all? Meaning they are tight?
Which I don't do... as all my trailer maintenance guides say, tighten the castle nut, but then back it off to fit the cotter pin in it. That allows for just a very small amount of "play" when you test the wheels.
IME wheel bearings need to have the minimum amount of preload: my Dodge calls for 18 in.lbs. That is basically just over finger tight. Like many applications a little loose is better than a little tight. Wheel bearing directions tend to err on the side of looseness.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
