Poppy_s_5th_WheExplorerDec 01, 2013Wheel/Brake/Bearing QuestionHi All, I was having some poor braking on our last trip so, after scolding myself for failing to adjust the brakes or lube the bearings since we got the trailer (probably 12,000 miles ago) I decide...Show More
BillB3857ExplorerDec 06, 2013Don't the pinion bearings in the rear axle also operate in a flooded oil bath? That is quite different than being grease packed.
Related ContentJacking/Lifting Trailer for Wheel Bearing/Brake Service?Wheel Bearings, Brakes, TiresWheel Bearing OR Brake Failure?Wheel bearing failure, now no trailer brakesWheel bearing failure, now no trailer brakes
