Monty-RobExplorerMay 21, 2013When to use water pressure regulator on fiver?Recently we were at a campground that had 40psi for water coming into our fiver. Normally we've seen 50+ or 60+. The question I have is if water pressure is low I am guessing you do not need a regul...Show More
steelpony5555ExplorerMay 21, 2013If you use one of those cheap RV ones it will reduce the amount of water you get.
Related ContentWater Pressure RegulatorWater pressure regulatorPressure Reducing Regulator Settingwater pressure regulatorswater pressure regulators
