ol_Bombero-JC
May 21, 2013Explorer
steelpony5555 wrote:
Don't use one and havn't for some time now. I stay in larger parks and doubt they have a major problem with pressure or they would not be in business. Many of these leaks and blow outs are weak spots in the RV, not because there was excessive pressure. Maybe someday I will find that park with 80 psi of pressure and will spring a leak and start using one,,,,maybe.....
Burst hoses or plumbing "mishaps' (leaks) aren't bad if/when thery're outside.
Inside is a whole different "maybe" story!.:S
Spent 30 years checking lots of city water pressure as part of my job.
Eighty (80) psi is "standard" throughout the city where I worked - including at the two campgrounds there.
If it's regulated (reduced) *at* the campground, great.
If not - or their regulator fails - you get what they get..:@
Some areas of Los Angeles County CA receive 100 psi on the main along PCH. Maybe the same main for campground in Malibu - maybe not.
Your dice to roll..:C
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
