Monty-RobExplorerMay 21, 2013When to use water pressure regulator on fiver?Recently we were at a campground that had 40psi for water coming into our fiver. Normally we've seen 50+ or 60+. The question I have is if water pressure is low I am guessing you do not need a regul...Show More
WoodGlueExplorerMay 22, 2013Pex or no Pex, you have fittings and in-line water filters that can't handle the higher PSI water pressure.WoodGlue
Related ContentWater Pressure RegulatorWater pressure regulatorPressure Reducing Regulator Settingwater pressure regulatorswater pressure regulators
