NMDriver
Sep 04, 2015Explorer
kyle86 wrote:
If you're livng out of your rv what do you do? Have to use the bathroom/shower and use the faucets. What is the routine?
Disconnect the water hose and drain it. Keep the heater going inside and it keeps the fresh tank and all the lines warm. I have so many air leaks in my RV that I suspect I keep the whole area warm.
I have only been caught in real cold weather a couple of times while in the RV but if you are living in it the heater should keep everything from freezing.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
