deltafired0g55s
Mar 12, 2024Explorer II
The breaker you show is not a double pole breaker. It is two single pole breakers in a single 1" space, often called a twin breaker. They are made in 2-15 amp, 15-20 amp, 2-20 amp, 15-30amp, 20-30 amp and 2-30 amp and others. If you have two wires hooked up to the breaker, you have two separate 120 volt circuits. Be careful what you do, you may cause a fire, or worse zap yourself. Former electrical contractor.
About Fifth Wheel Group
