djousma
Sep 19, 2017Explorer
Second Chance wrote:djousma wrote:
I cant give you a specific answer, but if you turn it on, and follow the sound, you should find it. sometimes in cupboard under the sink area, sometimes in other cabinet.
X2 ^^. I've seen a number of fifth wheels of different manufacture with the water pump in the "utility" area behind the front storage compartment under the bathroom. Often, there is a thin panel separating the "basement" from this utility area which contains the water heater, main heater, water pump, etc.
Rob
Thanks Rob. I should have called that out too. On my Cardinal, the water pump is in the basement, behind a bulkhead wall that requires the removal of half a dozen or so screws to get at.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
