ol_Bombero-JC
Nov 11, 2014Explorer
crewstx wrote:
I want to use balance beads in my new G614 tires but I do not know which beads to use or where to get them installed. The dynabeads supplier in NY says that I need the larger beads for an RV and they will not go through the valve stem and should be installed by someone experienced with them so as to not get the sealant gunk inside the tire and stick to beads.
Which beads are you using by brand and size and how were they installed? If I need an experienced installer, do you know of one near Houston, Tx. ?
Research -
Centramatics (located in TX)
and
Balance Masters (CA)
You can find info (at least for Centramatics) on YouTube.
Nothing *inside* the tire/s.
Remove all external weights. None needed.
(No *internal* beads or powder)
Many big rigs run Centramatics - I tried them, but they didn't leave enough thread exposed (in my opinion) for the lug nuts.
Returned them - no problem.
Went to Balance Masters.
Very Satisfied - Excellent product!..:C
YMMV
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
