crewstx
Nov 10, 2014Explorer
Which balance beads where to get installed near Houston, TX
I want to use balance beads in my new G614 tires but I do not know which beads to use or where to get them installed. The dynabeads supplier in NY says that I need the larger beads for an RV and they will not go through the valve stem and should be installed by someone experienced with them so as to not get the sealant gunk inside the tire and stick to beads.
Which beads are you using by brand and size and how were they installed? If I need an experienced installer, do you know of one near Houston, Tx. ?
