Bill_I's avatar
Bill_I
Which is best for pulling a fifth wheel, short or long box?
We are getting ready to purchase a 1 ton Dodge or GMC Denali PU to pull an overall length fifth wheel of 37 feet. Could we get some opinions on whether to go with a long box PU (8 foot)or a short box (6 1/2 foot). We are planning on being fulltime RVers for a couple of years.
  • If you read his original post you will see he's talking going full time for at least a few years------ 37 foot fifth wheel ,that's going to put you in the twelve to fifteen thousand pound range.(or MORE).
    Okay--- so that question was answered if you read it.:S
    Long wheelbase is going to give you a much better ride ,and more capability of carrying extra stuff---(in the bed ).. if you're going full time ----you say you are..:W
  • What weight 5th wheel........that is more important on truck choice then length
  • Another point is that a long box (almost) always has a more comfortable ride (towing or solo) due to the longer wheelbase.
    (I say almost, because somebody who has modified the OEM suspension or added air-bags or something will come in and be willing to argue with a fence post about ride comfort.)
    ON EDIT: Good point, Bob. I was typing at the same time that you were.
  • Either one is good. Check into a good slider hitch if going with a short box. I chose the short box, and have a pullrite auto slide and like it a lot. My reason for the short box was partly in the trucks wheel base, figuring there would be better manuvering in camp grounds. I believe you get a better ride with the longer wheel base, but I have no complaints with mine.
  • Your choice. I use a short box with an autoslider hitch. I wouldn't chance using a short bed without an autoslide. Too easy to damage your truck. If you are going to be traveling a lot, I would probably just do the long bed. I like my short bed, but my next truck will probably be a long bed so I can get a hitch I can remove by myself. My autoslider takes 2 people to load or unload.
  • Which cab?
    I would suggest an extended or quad cab with a short box.
    This will enable you to carry passengers.
    The short box will or you should have a slider style hitch.
  • For pulling, the long box without question. Short box works, but is a compromise with non-towing uses.
    More importantly, for a 37' fiver, you will want to consider a dually, and as far as I know, they are currently only offered with a long box. When you do the math on the load capacity you need, the box length decision may be made for you.
