- rcpd34ExplorerThanks for all of the input. I did look at both and I found the Voltage seemed to be made better and was heavier duty. It has 8 lug axles while the Torque had 6. Torque had the Onan 4000 and the Voltage has the 5500. It also had some extras like patio kit with rails, more storage and better cabinets. So I'm going with the Voltage and I pick it up Monday. Anyone here have one to discuss?
- 2001400exExplorerOn the voltage, I'd check the hitch weight. The brochure I read says it's 1,881 pounds dry. If you have ever put 2,000 pounds on your pickup, you'd know why I question it. I've had 2,000 pubs of rock in the bed of mine and I wouldn't want to drive very far like that.
- tinner12002ExplorerTorque is Heartlands lower quality hauler so with that being said I'd go with the Voltage, more of a higher end hauler in my opinion. I would think that a lot of the things that are standard on the Voltage would be listed as options for the torque.
- azdryheatExplorerVoltage is a luxury toy hauler. Torque is the bottom feeder for Heartland behind the Cyclone, Road Warrior, and Edge. Pay close attention to the specs, compare them.
- FireRobExplorerDepends if I'm throwing lightening bolts or twisting wrenches. Each has heir place.
Sorry couldn't resist. But watching the tread with interest. I have found floor plans by both that I like - The_real_wild1ExplorerHave you looked at both? I found looking at them inside and out side by side or even the same day helps make that decision pretty easy. There is some cheap junk out there and if you look at enough it really shows.
- lawrosaExplorerClearly the torque is the superior model.. better layout IMO..
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
