Toolguy5
Jul 19, 2015Explorer III
If you decide to go full time in a fifth wheel. The best floor plan that may suit your needs would be one that has the master bedroom over the king pin. And a closed bunk entertainment room in the rear for the kids. This will give the kids the privacy they will want, as well as a place to be in rainy days.
This may also deaden the sound a little for your husband to sleep or study.
Down side is living quarters will be smaller.
Your best bet is to search as many floor plans as you can and get the one that best suits you.
I would also make sure it is a subzero unit this will help in the colder weather but not eliminate all of the issues that comes with cold weather. It does make things easier if you will in one spot for 2 to 4 years. You can do things to the exterior to help out. Skirting and heat tapes will help with freezing water.
Good Luck.
Good Luck.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
