BeerCan
May 27, 2013Explorer
Cummins12V98 wrote:
AS for the BS about the 110# rims weigh your 4 tires and use the inflation chart for the G tire and add 5psi to what is recommended and you will be running around 80-85 psi. This is directly from GY tech support for when you are up grading the tire to a higher rating.
I don't understand the logic of this. If you are going to run the GY614's at 80-85 psi why not save a bunch of money and just get the R250's or Ribs? IOW why spend all that money and get no benefit?
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 22, 2026
