Binkley2
Jan 15, 2015Explorer
Which tow rig?
I recently purchased a 40' fifth wheel toy hauler, triple slide. The dry weight is 14,050 lbs., I figure 1000 lbs. of gear, my motorcycle is about 950 lbs., hers is 650 lbs. We try to two with minimal...
Cummins12V98 wrote:rhagfo wrote:Cummins12V98 wrote:tdst51 wrote:avvidclif1 wrote:
I don't think there is a plugged nickels worth of difference in the towing of the big 3. Figure out how much truck you need. Towing and payload primarily. That's your baseline you can't go below, if it's a dually so be it. Then start shopping for the one you like the best or get the best deal on. All have the same warranty.
But not all have the best engine. Ford has a converted gas engine, and Chevy has an Isuzu.
"Ford has a converted gas engine" Please explain?????
I agree on "not all have the best engine" part.
X2,
Thought the Scorpion was designed and built from the ground up by Ford.
Could be based on two Pinto motors side by side???
