rctoyguy wrote:
We are planning to trade our TT for a 5er - my truck does not have the fifth wheel prep or whatever (not predrilled for hitch).
Would you allow the camper store to install a 5th wheel hitch, or better off going to like a U-Haul or somewhere? Small mom and pop camper dealer or mega-store?
I absolutely want it done correctly.
Do you have the skills to do this yourself? If yes, then go to Etrailer.com, buy the hitch you want and knock it out.
If you don't........hmmm. Most RV places will do hitch installs. You might see if the place you're buying the 5er will make it a package deal? I've always done this kind of stuff myself so I can't really say which is best.
One question you must answer is if you want the bed completely clean when the hitch is out or if you don't mind having 5er rails there permanently.
Your truck will have to use an aftermarket 5th wheel mounting system. Starting in '14 RAM introduced the factory 5th wheel prep and gooseneck packages. Regardless of what anyone tries to tell you, the factory 5th wheel prep WILL NOT fit your truck.
Now that we have that clear let's get to your options. For a clean bed when the hitch is removed I'd suggest the
B&W sliding hitch with Gooseneck combination. The advantage is you have gooseneck towing capabilities if you need it. If you have a buddy that can help you this hitch only requires drilling ONE 4" hole in the middle of the bed of the truck and four 3/8" holes for the safety chain u-bolts. All mounting points on the frame use OEM holes so no drilling required there.
If you don't mind having permanent rails then the
B&W Patriot sliding hitch with custom rail kit will suit you just fine.
Your signature doesn't say what bed length you have but I assume it's a 6' bed. If so you really should get a sliding hitch like the ones I linked above just in case you might need it. If your bed is 8' your
options are much cheaper.KJ
