- Blanco1Explorer
colliehauler wrote:
Some mfgs offer a generator prep pkg. If available you could reuse your Onan.
I know Jayco does.
But would my 2.8 be big enough for the A/C in a 5th wheel?
& might I be able to hook it up to my Yamaha 2000 Geni to bump it up to a 4800 geni?
The factory geni would be about a 5500 Geni. - colliehaulerExplorer III
Blanco1 wrote:
The little 2.8 would run one major draw. A 5500 would run most of everthing at the same time and be quieter as well. No on hooking the Onan and Yamaha together, not designed to be bridged.colliehauler wrote:
I know Jayco does.
The factory geni would be about a 5500 Geni. - laknoxNomad
Blanco1 wrote:
laknox wrote:
Nearly all mfrs offer OEM gennies in their bigger rigs, as far as I can tell.
Lyle
Well.... I'm looking at staying under 30 feet if I can.
Lyle:
Unless you're looking at a TH, you're unlikely to find an OEM genset. Not saying that they're not available, but unlikely. I do know that Jayco's Eagle HT 27.5RLTS is now available with genprep, and it's right at 31'. Not sure about the other Eagle HTs.
Lyle - Blanco1Explorer
laknox wrote:
Blanco1 wrote:
Lyle
Lyle:
Lyle
Yes they are offered in other Jayco Models. - Blanco1ExplorerLooking at this http://northwoodmfg.com/arctic-fox-2/arctic-fox-28-5c/ looks like the option is for a 3.6 Onan Propane Geni...
I'm thinking if thats the case maybe buying a 2nd Yamaha 2000 Geni & hooking it up to my other 2000 I currently own, I might be fine?
It would save me a few Grand?
& allow me to run Gas vs propane?
Being I'm told use so much fuel?
I would mind turning off the A/C while using the Microwave & things like that.
Yet the simply push a button with no prep is still very attractive?
https://www.youtube.com/watch?v=08Dvg0dCZgg - tinner12002ExplorerEven though I have a built in gen on my Raptor, I also use, because I already have it, a Honda 2000i gen that we use just for coffee maker, music soundbar and general 120v stuff along with charging the batteries. If the temps outside are mild, I'll run it all night with a couple fans on instead of the Onan, only because the Hondas use very little gas. Once we start full timing the Honda will go away.
- The way I see it , It will depend on what your wants and needs are.. I used to run my fifth wheel with 2 Honda eu2000's running in parallel.. I made a 5 gallon extended run fuel tank and that allowed me to run my entire trailer for many hours without refilling the fuel..
BUT, I still had to get everything out and hook it up , fill the fuel tank, I had to carry and store both gennies. and the cable and locks to keep them mine..
That way worked great and I was very happy doing things that way.. When I fell onto a deal, and was able to get an Onan 6500 installed I jumped at it..
Now , I just push a button.. and LOVE IT ! ! ! - ol_Bombero-JCExplorer
Blanco1 wrote:
I'm 90% sure I'm gonna buy a factory installed Geni 5th wheel,& want to narrow down my list of who offers that & who dont from the factory?
Almost any manufacturer will be HAPPY to take your $$ for a factory installed gen!!
There are better options than "factory installed".
You need to re-visit your other post.
Bottom line - it's your money!
Order with Generator *PREP* - decide later if you need one or not.
Buy the gen of your choice - at a much better price, or pay more now.
Good luck.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
