Community Alumni
May 08, 2016On my trailer there isn't any tape on the slides, only caulk. But the flap is only a weather seal to keep out rain or snow. It is not the seal to keep cold or heat in or out. So, when the slides are out the flap is 2-3 inches away from the caulk at the inner seam of the rubber roof and rests on the rubber roof material. When the slides are in the flap passes over the caulk on the outer edge of the roof material and rests on a metal edge of the slide wall. The caulk has never been effected by the flap. And when we set up camp I check the flaps to be sure they are flipped outward and if not I use the awning pull rod to pull them out, Takes about a minute for 3 slides.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
