Abby Normal wrote:
I have received a lot of education from this forum, but I am back with another question. I have learned that my TV payload is 10,000 lbs. and that the GCWR is 23,500 lbs. The TV with passengers and EXTREMELY LITTLE cargo is 8280 lbs. This leaves 15,220 lbs. for trailer, hitch, and cargo. If I allow 300 lbs. for the hitch and 1200 lbs. for cargo, I have 13,720 lbs. for trailer, right? Not so fast. If the TV only carries 10,000 lbs. and we weigh 8280, we only have 1720 lbs. left for pin weight. What about the weight of the hitch? If the hitch weighs 300 lbs. we now only have 1420 lbs. left for pin weight. Why do manufacturers sell units as 1/2 ton towable when I can't get the math to work for our F-250 diesel?
I don't think you have a 10,000 lb "payload"....maybe a 10,000 GVWR.
So if your truck's GVWR is indeed 10,000 and it weighs 8280, that leaves 1720 lbs for "payload" which includes the hitch, pin weight, and anything else you put in the truck. Only you can come up with the correct figure.
Ron
