Hammerboy
Feb 20, 2021Explorer
Old-Biscuit wrote:work2much wrote:dieseltruckdriver wrote:
It is due to the frame stresses. Look at how heavily built your goose neck trailers are up front. It would cost too much to build an RV that heavy.
Most of the RV's on the market have frames made by Lippert. Lippert endorses the use of the Reese Goose Box with their frames so apparently the frames don't need to be any heavier or cost anymore than they already do.
I'm with Adamis, they should at least make it a factory option so you don't have to toss the factory boat anchor when you make the swap. New Horizons makes the Gen Y available on their units.
Aside from ease of hitching there is a lot to like with a gooseneck over a std. hitch.
Lippert 5th wheel frame failures and these were using standard 5th wheel hitch....Lippert/JUNK ---words are interchangeable!
Lippert approves Reese Goose Box cause THEY own it
Could Post all day long but you should do a little bit of research.
To be fair Lippert builds them to what the rv manufacturer designed. Lippert could build the most stout frame imaginable if the rv manufacturer designed the frame that way.
Dan
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
