Lantley
Feb 21, 2021Nomad
Durb wrote:
I have a trailer Saver now (TS3). If I were to make a change I would consider the Goose Box as it has some real design advantages. The attachment point to the truck is low reducing the hitch angle which reduces the amount of chucking forces relative to bouncing forces created by the trailer. Consider the Goose Box image; the forward high hinge point relative to the ball will allow the hitch to retract some when compressed thus mitigating some chucking forces. Solid engineering was used when designing the box.
Any type of soft joint hitch/pin box has to be easier on the trailer frame than a solid hitch and solid pin box.
Yes But the long shaft of the adapter will always create more leverage on the pin box. I don't think I can consider the Goose box a foolproof advantage for 5th wheel towing unless the pin box attachment to the fiver is also altered and reinforced in someway.
A long pipe on a pipe wrench will always create more force/leverage on that lug nut and allow you to turn the nut vs. a wrench with no extension.
Air cushioning and absorption are secondary factors.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
